The fuel pump will not shut off when you turn the key to run. The relays click spastically and once in a while the pump will stop. When the pump does stop the truck will start and run for a moment. If it does not stop, the truck will not start. It cranks no problem. Battery charged, new fuel pump relay, same problem. This happens with both tanks. Please help!
Aug 25, 2014 at 1:50 AM
