Fuel pump will turn on but does not deliver fuel
235,768 MILES • 5.6L • V8 • 4WD • AUTOMATIC
04TITANHASMESTUMPED
Pump will turn on but will not deliver fuel. I can run a hot wire to the pump and it will work. Installed new fuel pump new IPDM. All I can think is it is getting low voltage to the pump. What is is correct voltage for pump to work?
Apr 20, 2018 at 2:18 AM
Good afternoon.
The voltage to the pump is battery voltage.
Attached is a wire diagram. check the black/yellow wire for battery voltage while cranking.
Apr 20, 2018 at 4:05 AM
