After replacing the fuel pump the engine cranks but does not start?
124,556 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BRENDALU
I replaced my fuel pump, and my car turns over but doesn’t start. I tried checking the fuse box, I tried to reconnect the fuel lines that sit on top of the pump.
Mar 6, 2025 at 8:09 AM
  • 110,248 POSTS
Do me a favor. See if it starts if you use starting fluid. If it does and then stalls, we still have a fuel related issue. If there is no change, I need you to check if there is spark to the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results.
Mar 6, 2025 at 11:11 AM
