My truck will not start. Fuel pump. At first I could tap the fuel tank with a wrench next to the fuel pump and it would start. Now it wont. Put a new relay in, but still wont start. The relay is not clicking when I turn the ignition to accessory. I am guessing the pump is bad. I have not pressure tested anything because I cant hear the pun running like I could before so bad pump right? To replace the pump cannot I jack the bed up and block it to access the pump in the gas tank? Do I need to loosen the tank bolts some or not? What is the easiest way to replace the pump?
Jul 2, 2016 at 2:26 PM
