After replacing the fuel pump, the fuel gauge stopped working
91,000 MILES • V8 • 2WD • AUTOMATIC
OBRADLEY73
Fuel Gauge not working properly after replacing fuel pump.
May 20, 2022 at 3:03 AM
SQM
  • 6,383 POSTS
Did the new pump come with a fuel level sending unit?
It could be due to a faulty sending unit on the new pump or there is a loose connection for the sending unit.
Is the pump working properly?
Did you have this issue before the pump replacement?
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Let me know of any questions.
May 20, 2022 at 9:18 AM
OBRADLEY73
No. I did not have this problem before having the pump installed by AAA.
May 30, 2022 at 10:04 AM
SQM
  • 6,383 POSTS
So, this is likely due to having a sending unit issue with the new pump.
If the work was done recently, it should be covered under warranty.
I would suggest calling the shop and let them know about the issue.
May 31, 2022 at 2:10 AM
OBRADLEY73
Okay. Will take it back to AAA and let them know. Thanks.
Jun 1, 2022 at 4:17 AM
SQM
  • 6,383 POSTS
You are welcome. Let me know how it goes.
Jun 1, 2022 at 7:55 AM
