Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Previa
Fuel System
Fuel Pump
Relay
Location
Where is the fuel pump relay located?
1997 TOYOTA PREVIA
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
STINKERTINKER
MEMBER
1 POST
Need to find and remove relay, then to change fuel filter.
May 11, 2022 at 8:11 PM
SQM
Experienced Mechanic
The fuel pump relay is located under the hood on the passenger side (see diagram below).
The fuel filter is on the driver side frame rail.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Let me know of any questions.
Images (Click to enlarge)
May 12, 2022 at 1:13 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
