Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
Protege
Fuel System
Fuel Pump
Relay
Location
Where is the fuel pump relay located?
2002 MAZDA PROTEGE
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
33FRANK33
MEMBER
1 POST
I can’t figure out where the location for the fuel pump relay is.
Jun 1, 2023 at 9:16 AM
BORIS K
Experienced Mechanic
The fuel pump relay is located in the main engine fuse block, just ahead of the driver's side front strut tower, next to battery. See images below.
How to test a relay:
Please let us know if you need any other help.
Cheers, Boris
Images (Click to enlarge)
Jun 2, 2023 at 12:42 AM
33FRANK33
MEMBER
1 POST
So, I know that the fuel pump relay is in the main fuse box under the hood, but my question is, what relay is it?
Jun 5, 2023 at 7:44 AM
BORIS K
It is the topmost relay, see image below.
Cheers, Boris
Image (Click to enlarge)
Jun 6, 2023 at 1:10 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
