Fuel pump relay location
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUBARU123123
Trying to find the location of the fuel pump relay, found 3 relays under the passenger glove box 2 white and 1 brown but not 100% sure on what one is for the fuel pump.
Jan 25, 2021 at 3:36 PM
SEVAG P
  • 405 POSTS
Hello.
Fuel pump relay located under the dash passenger side, check the pictures below, also procedure how to remove and reinstall relay.
check our guide how to test a relay.
let us know if you need more help.
thank you.
Jan 25, 2021 at 6:30 PM
