Fuel pump relay and fuse locations?
4WD • AUTOMATIC
OKIE_787
I’ve been told there are two fuel pump relays on this vehicle, but also that there’s only one. I need the diagrams for both fuel pump relay locations as well as the fuel pump fuse.
Sep 9, 2026 at 4:19 PM
MECHTRIX
  • 581 POSTS
The 2 fuel relays are mounted on a metal bracket together under the passenger side center consold footwell rug ..and the fuzes 2 of them one is in the fuze box near the batery its a 15 amp blue colored ...and the other ones in the regular fuze panel druvers side behind the change /storage pocket near you left knee 7.5 amp brown color good luck let us know what you find
Sep 9, 2026 at 6:33 PM
