Where is the fuel pump relay located?
160,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
MD-G
Hi, can you help me find my fuel pump relay?
Feb 11, 2021 at 11:55 AM
  • 110,251 POSTS
It on the passenger side under the dash. See pic 4.
Here are the directions for replacing it. The attached pics correlate with the directions.
_____________________________________
2007 Subaru Outback F4-2.5L SOHC
2.5L SOHC
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pump Relay Service and Repair Removal and Replacement 2.5L SOHC
2.5L SOHC
Fuel Pump Relay
REMOVAL
pic 1
1. Disconnect the ground cable from the battery.
2. Remove the glove box.
pic 2
3. Remove the harness cover (A).
pic 3
4. Disconnect the connector from fuel pump relay.
INSTALLATION
Install in the reverse order of removal.
_____________________________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 12, 2021 at 7:40 AM
