The fuel pump will not come on unless u ground it at the relay at the dash.
Mar 29, 2016 at 7:27 AM
FREEMBA
✓Experienced Mechanic
If grounding fuel pump relay terminal #3 causes the fuel pump to run, suspect corrosion on the RED/YEL wire which goes from the fuse box(G1/3) to the Digifant Control unit. The ECU is located in the air plenum on the left side of the engine compartment under the windshield.
