Where is the fuel pump relay located?
156,000 MILES • 2.0L • 4 CYL • AUTOMATIC
JOAKIMKO
Fuel pump relay location needed.
Sep 23, 2022 at 10:19 PM
MIKE H R
  • 3,094 POSTS
Center of dash, on bracket under radio, under engine control relay. Check the image (below). :) If there is just the engine control relay then it does both jobs the fuel pump and engine. Let us know how you make out.
Mike
Sep 24, 2022 at 4:28 AM
  • 55,806 POSTS
The fuel pump relay is interrogated into the TFI relay which is located on the passenger's side kick panel.
Here is an image of the location and a guide on how to test it in the images below:
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 24, 2022 at 4:29 AM
JOAKIMKO
thanks for reply. :) i appreciate it.
Sep 24, 2022 at 4:36 AM
  • 55,806 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 25, 2022 at 5:33 AM
