Fuel pump problems
200,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JINNY
Replaced fuel pump, took it for test drive and it started backfiring. Unplugged mass air flow and ran great yesterday. Went out this morning and it will not crank.
Feb 16, 2019 at 11:55 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with the mass air flow (MAF) sensor. I believe the vehicle's Power-train Control Module (PCM) needs to know how much air is entering the engine to know the amount of fuel to inject. Nevertheless, I have included a couple of links for you to go through down below. They should help you pinpoint your vehicle's problem. Please go through them and let us know what you find out.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Thanks,
Alex
2CarPros
Feb 17, 2019 at 6:23 AM
JINNY
Thank you for the information. My husband's working twelve hours a day this week. so as soon as he has time to check this out I will let you know what happens.
Feb 18, 2019 at 6:48 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Sounds great. Talk again then.
Thanks,
Alex
2CarPros
Feb 19, 2019 at 1:32 AM
