Fuel pump pressure numbers for this van
257,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
DENNY’S
Fuel pump pressure, what is the minimum and maximum fuel pump pressure for this vehicle?
Jan 15, 2019 at 1:24 AM
DENNY’S
I change the fuel pump pressure regulator because it was leaking, but now I only have about 30 pounds of fuel pump pressure on the rail. I don’t know if that is enough or not. I thought it was a lot higher than that.
Jan 15, 2019 at 1:30 AM
Good afternoon.
I posted the pressure below for you.
You need a fuel pump. 30 lbs. is way too low for the system.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Fuel Pressure * .................... 338 ± 14 kPa (49 ± 2 psi)
Jan 15, 2019 at 1:39 AM
DENNY’S
I was wondering, is there different pressure regulators that fit their vehicle? in case the one that I bought is too low pressure or you think it’s just the fuel pump? I replaced the fuel pump like five months ago from rock auto maybe it’s just a defective pump. thank you the pressure was real helpful.
Jan 15, 2019 at 2:30 AM
This is a failed fuel pump. Contact them as this should be covered under warranty.
Jan 15, 2019 at 6:28 AM
DENNY’S
Thanks for the help. I can get a new pump.
Jan 15, 2019 at 7:41 AM
You are welcome.
We are always glad to help.
Jan 15, 2019 at 7:54 AM
