Fuel pump pressure, what is the minimum and maximum fuel pump pressure for this vehicle?
Tuesday, January 15th, 2019 AT 9:24 AM
DENNY’S
MEMBER
I change the fuel pump pressure regulator because it was leaking, but now I only have about 30 pounds of fuel pump pressure on the rail. I don’t know if that is enough or not. I thought it was a lot higher than that.
SPONSORED LINKS
Tuesday, January 15th, 2019 AT 9:30 AM
MECHANIC
Good afternoon.
I posted the pressure below for you.
You need a fuel pump. 30 lbs. is way too low for the system.
I was wondering, is there different pressure regulators that fit their vehicle? In case the one that I bought is too low pressure or you think it’s just the fuel pump? I replaced the fuel pump like five months ago from rock auto maybe it’s just a defective pump. Thank you the pressure was real helpful.
Tuesday, January 15th, 2019 AT 10:30 AM
MECHANIC
This is a failed fuel pump. Contact them as this should be covered under warranty.
