Fuel pump power, circuit opening relay location needed
246,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
BILLY WINTERS
Need to know where COR is located.
May 18, 2020 at 9:18 AM
I attached the information on the circuit opening relay.
Also, here is a guide that will help with testing a relay in case you need this help as well.
Also, in case you need a little more info on how to use a meter which is helpful in these cases.
Please let us know if you need more info. Check out the diagrams (Below). Please let us know what happens. Thanks
May 18, 2020 at 11:07 AM
