Running rough, will not stay started
244,011 MILES
TERESA NUNES
Car shut off at stop would not stay started. Fuel pump or injector?
Jun 11, 2019 at 1:42 PM
Hi Teresa,
This sounds more like a pump then injectors. However, we will need to do some testing. Here is a guide that walks through the most common cause of these issues because a pump or injectors are not the only possible cause:
https://www.2carpros.com/articles/stall-at-idle
First, let's put a fuel pressure gauge on the engine and see what the pressure is. It should around 35-40 PSI.
Next we need to find out if there are any codes. I am going to guess there are not but we need to confirm that because if we have a code, this will really cut down on our search.
Let me know these two things and we can go from there. Thanks
Jun 12, 2019 at 5:36 AM
