Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Fiat
Siena
Ignition
Coil
fuel pump or coil pack
1997 FIAT SIENA
130,000 MILES
JEREMY2013
MEMBER
1 POST
The car drives or idles for 10 minutes then cuts out.it only starts after a few hours again and the same problem happens again.
Apr 15, 2013 at 6:36 AM
Experienced Mechanic
Check the fuel pressure if its within specs -start here
Apr 15, 2013 at 7:12 AM
WHen the engine doesn't start, check to see if the fuel pressure is within spec and check for spark. Let me know what you find.
Apr 16, 2013 at 1:28 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
