The car drives or idles for 10 minutes then cuts out.it only starts after a few hours again and the same problem happens again.
Apr 15, 2013 at 6:36 AM
✓Experienced Mechanic
Check the fuel pressure if its within specs -start here
Apr 15, 2013 at 7:12 AM
WHen the engine doesn't start, check to see if the fuel pressure is within spec and check for spark. Let me know what you find.
Apr 16, 2013 at 1:28 PM
