This could be a problem with your vehicle's Engine Control Unit[ECU] or a power or ground wire that goes to the ECU. n the diagrams down below I have included the fuel pump circuit wiring diagram and the engine control wiring diagram which shows the fuel injectors circuit. I have also included a diagnostic troubleshooting guide that explains how to test the fuel injector circuit to pinpoint what your vehicle's problem is from the vehicle manufacturer. You will need to use a Digital Multi-meter [DMM] to go through these guides, so here is a link below explaining how to use one, if needed:
Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Jan 19, 2020 at 3:41 AM
