fuel pump not working
261,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
FISH0505
fuel pump will not run or prime. replaced the FPCM and replaced the fuel pump. fuse are good. and the grounds are good. can straight wire the pump and will run. any ideas?
May 22, 2021 at 3:50 AM
  • 55,851 POSTS
It sound sliek the fuel pump relay is bad. To be sure this guide can help us fix it with the fuel pump relay location in the diagrams below:
Here is the fuel pump wiring diagrams as well so you can see how the system works. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
May 23, 2021 at 3:25 AM
