Hi I have a 1999 dodge grand caravan 3.3l the car start having problem once was empty I put gas and it's start again but after 1 minute start have problem and try to power off I check the fuel pump and flow but no like it should suppose one of the cable from the fuel pump plug I put a tester light and switch on and the light come onfor 1 second I check another one cranking the motor and the light sTay on I connect the plug with the 2 lines unplugged and no fuel flow I put a new fuel pump from advance auto and the pump make noise but don't flow gas can you help me with that thanks
Jul 14, 2015 at 12:59 PM
