what pieces go where on new fuel pump
188,000 MILES • 4 CYL • AUTOMATIC
SHAWN SODERS
I have no instructions for what pieces go where on new fuel pump and I am also having trouble to know if it is getting power.
Dec 12, 2017 at 10:51 PM
KHLOW2008
  • 41,812 POSTS
See if the diagram is of any help.
At the fuel pump connector there are 4 wires, two of them would be fine wires whilst the other two would be coarser. The coarser wires are for the power supply and ground. Use a test light to bridge across these 2 wires and turn on ignition switch. Crank engine briefly and if the test light bulb turns on, that would mean you are getting power to the fuel pump.
Mar 31, 2021 at 5:31 AM
