It will not turn over when cranking it. Before dropping the fuel tank to replace the fuel pump I want to x out the fuel pump driver or control module. The problem I am having is, I cannot seem to figure out if this year has a fuel pump driver module and if so, is it located above the spare tire and if not where? It is an extended cab. The following troubleshooting I have tested or replaced:
Starter solenoid.
Fuel filter.
Fuel pump relay (both).
Not getting noise in the tank when putting the key on start position
Any help and troubleshooting I can do before I determine it is the fuel pump itself? I only say this because it was replaced three years ago and it has a fuel tank. :/
Many thanks!
Bonnie
Starter solenoid.
Fuel filter.
Many thanks!
Bonnie
Sep 15, 2018 at 5:21 AM
