I purchased a new fuel pump and installed it. It ran fine for 4 days or so then it began to cut out extremely bad on the highway and was sheer luck If it even started for me half of the time. It’s a brand-new pump but also in the fuse compartment under my hood, the 20 MPH fuse for the fuel pump has zero power in the port it goes into now. Where should I start?
Thank you
Thank you
Sep 3, 2024 at 2:00 AM
