2016 Chevrolet Silverado Fuel Pump Module
80,000 MILES • 5.3L • V8 • 4WD
DPS1028
Checked power to the module at fuse box and got 12 volts. Main power at module, Red wire with purple at module connector only has 1.4 volts. I cannot find a broken connection. Any ideas?
Aug 14, 2023 at 12:35 PM
  • 55,721 POSTS
The first thing I would do is check the ground at the driver's door on the body frame mount. Also, here are the wiring diagrams for the fuel pump driver module so you can see how the system works. Check out the images (below). Please let us know what happens.
Aug 15, 2023 at 3:53 AM
DPS1028
Thanks for the wiring diagram, Ken! After testing wiring at module and at fuse box I found a drop in voltage on the red/violet wire between the FPPM fuse and halfway point to the rear FPCM. The voltage drops to 2 volts. Ran a jumper around the problem area and truck started right up. Now I need to find the damaged spot and repair. Ground wires checked out fine.
Thanks again for the information.
Aug 21, 2023 at 4:42 AM
DPS1028
The break was in the square tube where the loom makes its turn under truck frame right under fuse panel on drivers side.
Aug 21, 2023 at 11:58 AM
  • 55,721 POSTS
That's what I am talking about, great find! Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 22, 2023 at 4:17 AM
DPS1028
Thank again for the schematic. I couldn’t find it anywhere else online!
Aug 22, 2023 at 8:01 AM
MICAH KING
I don't have power at the fpcm but I have power at the fuses, I cleaned up the ground at the driver door on the frame rail and still the same result
Sep 30, 2025 at 5:50 AM
  • 55,721 POSTS
Did you replace the FPCM?
Oct 1, 2025 at 2:29 AM
JCKTIGER02
Truck won't start. Getting P018B and U18A2. Had an issue a few years ago very similar. I replaced the FPDM and fuel pump. Ended up taking it to Chevy and they fixed the issue(not sure of what they said they did). I'm now having the same issue. I was idling and the truck died and wont start again. I replaced the sensor fwd of the tank and the truck worked again for a day. Back to no start. The pump and control module have less than 20k on them so I'm pretty certain it's electrical. I made sure the ground below the driver door was good. I opened up the harness going to the control module and it looks like this. Im not sure if this is correct. I can't find any diagrams. The blue wire goes into some sort of splice and then comes out the other side with no shield. Is twisted around these 2 wires with this metal temp tape and it goes all the way fwd. There is another wire in the back that goes from grey to red to grey and back to red with 3 in line splices(doesn't seem right). The blue/exposed wire pins in 15 and the the two twisted that are wrapped in heat tape pin in 8 and 16. The third photo is further fwd. It looks as if it supposed to be like that because it doesn't look like anything is wrong at the point. The first two are 6-18 inches fwd of the FPDM. Any advice? Thank you in advance!
Apr 25, 2026 at 12:14 PM
Suggested Repair
Check the driver-door body-frame ground and the fuel pump control module wiring. On this truck, voltage dropped on the red/violet power wire between the FPPM fuse and the rear module; the damaged section was in the square tube where the loom turns under the frame beneath the driver-side fuse panel. Repair that wiring rather than replacing the module if power is present at the fuse but not at the module.
Conversation Summary
The owner of a 2016 Chevrolet Silverado had no communication from the fuel pump control module. Power was present at the fuse box, but the red/violet wire at the module had only about 1.4 volts and no obvious break. The expert suggested checking the ground at the driver's door body-frame mount and reviewing the module wiring diagrams. Further testing found a voltage drop to about 2 volts on the red/violet wire between the FPPM fuse and a midpoint toward the rear module. A jumper around the damaged section allowed the truck to start, and the break was located in the square tube where the loom turns under the frame beneath the driver-side fuse panel. Later posts described similar no-start and power-loss symptoms, but no additional confirmed repair was established.
