Where can I purchase an after market Fuel Pump Assembly?
1997 TOYOTA TACOMA
195,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
KRISTIMC00
Need fuel pump assembly including bracket and fuel pump. Can't afford dealer parts prices. looking for a good aftermarket. Squirrels ate up fuel lines and when we tried to remove fuel line from fuel pump bracket we broke metal fuel line on top of bracket.
Sep 22, 2021 at 6:21 AM
We are not a parts site but here is a link to the most popular parts site that most of us use. This has the pump and housing assembly.
https://www.rockauto.com/en/catalog/toyota,1997,tacoma,3.4l+v6,1279009,fuel+&+air,fuel+pump+&+housing+assembly,10147
Also, incase you need it, here is some info on how to replace the fuel pump. Here is a guide that has some good info in it:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Also, please see the info below from the manual that will help as well.
Please let us know if you need more info. Thanks
Sep 22, 2021 at 8:52 AM
KRISTIMC00
Thanks Kenny. this is a blessing $106.00 vs $700.00 from dealer. Can you help me with one more thing? which fuel filter would you suggest I get from Rock Auto?? I plan to order these parts at the same time. You are a true angel.. Kristi Mc!!!
Sep 24, 2021 at 2:47 AM
You are welcome. I would suggest the AC Delco or Wix. They are the most common and well known brands. I don't think you can go wrong because there is not much to a filter but those are the name brands that I would go with given those options.
Thanks again for using 2CarPros.
Sep 24, 2021 at 8:09 AM
KRISTIMC00
Awesome.. thanks for all your advice.
Sep 24, 2021 at 8:17 AM
