If the fuel pump is working and the fuel filter is fine what else could make car start idle and shake and then it turn off?
Sep 30, 2022 at 3:11 AM
✓Experienced Mechanic
This could be the IAC motor, vacuum leak, bad spider injector, weak fuel pump. bad PCM for starters. Let's start by running the codes this guide can help:
