fuel pump
2007 LINCOLN NAVIGATOR
NICOLE102612
Im having problems finding the fuel relay switch on a 2007 Lincon Navigator. I need to know where it is located. Also I would like to know if there are any other things to check for when it comes to a fuel pump problem I have reset the fuel reset button and checked the fuses. I had the oil changed before it quit running as well so Im not sure if that may have affected something it ran great before i had the oil changed.
May 29, 2013 at 3:28 AM
DOCFIXIT
  • 18,828 POSTS
Inertia switch left rear corner trunk
May 29, 2013 at 4:01 AM
NICOLE102612
no, that is the fuel reset button i had a dealer tell me that there was a wire that comes out from the gas tank and your supposed to follow the wire back and there is a relay switch under the vehicle that can sometimes get nasty and not work. I need to find it under the vehicle and make sure that isnt the problem before i go spending 3 or 4 hundred dollars on a fuel pump ive searched and searched the internet and cant find anything.
May 30, 2013 at 6:55 AM
DOCFIXIT
  • 18,828 POSTS
I know of no such wire
May 30, 2013 at 10:57 PM
