Fuel pump swap with universal inline fuel pump
270,000 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
CELAM7939
  • 6 POSTS
Will a universal inline fuel pump work on the truck listed above 1500 4 door truck?
Jul 10, 2019 at 7:01 AM
Good evening,
It needs to be a pump that is regulated to 50 lbs. That is what your truck requires.
Why not replace the pump in the tank?
A pump from rock auto is $48.00.
Jul 10, 2019 at 7:45 AM
CELAM7939
  • 6 POSTS
Where is rock auto and how can i get it?
Jul 10, 2019 at 7:46 AM
CELAM7939
  • 6 POSTS
And is that all i need to do and the truck will be working?
Jul 10, 2019 at 7:47 AM
Go to there web site. Put in your truck and go to the fuel pump. They usually deliver the next day.
I attached the picture of the pump for you.
Jul 10, 2019 at 7:48 AM
I assume so since you asked for it. Did you determine it was failed?
Jul 10, 2019 at 7:49 AM
CELAM7939
  • 6 POSTS
Yes it is the fuel pump.
Jul 10, 2019 at 7:50 AM
Okay, contact them for your pump.
Jul 10, 2019 at 7:55 AM
CELAM7939
  • 6 POSTS
Is it possible that the filter for the fuel is bad? and it shows the same symptoms of a bad fuel pump.
Jul 12, 2019 at 9:07 AM
No. There is a bypass in the filter.
Jul 12, 2019 at 9:21 AM
