Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Fuel System
Fuel Pump
Fuel pump
2000 CHEVROLET SILVERADO
15,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
BLUEHOUND
MEMBER
Can I add electric fuel pump in the gas line with a filter is and leave the stock pump in the tank? thank you. Rick
Jul 17, 2019 at 7:55 AM
Experienced Mechanic
Good evening,
No, it will not work. The old pump in the tank will be a restriction for the flow of fuel.
If the pump is bad, you need to drop the tank and replace the pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jul 17, 2019 at 8:00 AM
BLUEHOUND
MEMBER
Thank you that helps a lot . Rick
Jul 17, 2019 at 8:06 AM
You are welcome.
Always glad to help.
Jul 17, 2019 at 8:07 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
