Fuel pump
15,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
BLUEHOUND
Can I add electric fuel pump in the gas line with a filter is and leave the stock pump in the tank? thank you. Rick
Jul 17, 2019 at 7:55 AM
Good evening,
No, it will not work. The old pump in the tank will be a restriction for the flow of fuel.
If the pump is bad, you need to drop the tank and replace the pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jul 17, 2019 at 8:00 AM
BLUEHOUND
Thank you that helps a lot . Rick
Jul 17, 2019 at 8:06 AM
You are welcome.
Always glad to help.
Jul 17, 2019 at 8:07 AM
