Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Peugeot
207
Fuel System
Fuel Pump
Replace/Remove
fuel pump replacement, where is the access panel?
2007 PEUGEOT 207
62,000 MILES • 1.6L • TURBO • 2WD • MANUAL
LEEDSFAN
MEMBER
I need to change the fuel pump where is the access panel? please
Jan 7, 2025 at 9:18 PM
Experienced Mechanic
On the 2007 Peugeot 207, the fuel pump access panel is located under the rear seat on the passenger side. Let us know if you need anything else.
Jan 9, 2025 at 3:18 AM
LEEDSFAN
MEMBER
thank you.
Jan 9, 2025 at 7:02 PM
You are welcome, please use 2CarPros anytime we are here to help.
Jan 10, 2025 at 1:31 AM
Add image or video
Ask a new question
Engine has low power
Engine won't start
