Fuel pump not working
180,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
HEIDE1234
Started cutting out and would shut off, would not start back up. Let it sit for couple hours started and ran for a week then cut out again in town. Now will not start and fuel pump is not working. Checked fuses and swapped relays around. What should I try next? I do not feel it is the pump itself.
Jul 2, 2018 at 4:35 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I have dealt with many in-tank fuel pump problems and this sounds like one. I would suggest performing a fuel system pressure test. Many auto part stores have tool loaner programs(AutoZone,Pep Boys, O'Reilly's) to rent you a tester. With the key on engine running pressure should be 28-45 PSI and key on engine off should be 35-45 PSI. You can find a Schrader valve on the fuel rail to attach the pressure tester. I am attaching a tutorial on how to test the fuel pressure and how to test the fuel pump relay. Hope this helps and feel free to ask any questions. Danny-
Jul 2, 2018 at 10:47 AM
BMDOUBLE
  • 1,139 POSTS
Symptoms match perfectly with a failing fuel pump. It’s right at the mileage when they fail, see them all the time at my dealership. But by all means do your tests.
Jul 3, 2018 at 12:58 AM
