I installed a new fuel pump in a 2002 Buick Rendezvous and it still will not start after installing it what could I do next?
May 11, 2016 at 8:09 AM
HMAC300
✓Experienced Mechanic
try resetting security system, most likely that was the original problem. see pictures.
Image (Click to enlarge)
May 11, 2016 at 8:19 AM
RENEE L
MEMBER
Hi Alex,
If resetting the security system does not work. Here is a link to an informative article from this site with step by step instructions and photographs on what to check for when your vehicle will not start.
Thank you for visiting 2CarPros.com.
