Fuel not getting to the engine
70,000 MILES • V8 • 4WD • AUTOMATIC
KLROBER89
Fuel pump went out, change the pump and the filter, change spark plug. gas not getting to the engine. I do not what what else to do.
Sep 8, 2019 at 4:13 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You might want to check the fuel pump relay to see if working.Here is a tutorial showing how to test:
I've attached a picture below of its location.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 8, 2019 at 8:19 AM
KLROBER89
Change that also.
Sep 8, 2019 at 8:21 AM
DANNY L
  • 5,648 POSTS
Hello again.
Have you tested the fuel pressure recently? It might be possible you got a defective/weak pump. If you don't have access to a fuel pressure tester your local auto parts stores have a tool loaner program and will rent you one.Here is a tutorial showing what is involved:
I've attached below the fuel pressure specifications for your car as well as a wiring diagram.Hope this helps.
Danny-
Sep 8, 2019 at 11:17 AM
KLROBER89
Sep 8, 2019 at 11:20 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Let me know what you find after checking all this.Thanks again for using 2CarPros.
Danny-
Sep 8, 2019 at 11:33 AM
