Will not start
180,000 MILES • 2.7L • 6 CYL • 4WD • AUTOMATIC
MARSHA HICKS
Replaced the fuel pump but still wont start. is there a reset button that I need to push? Where is the reset button located?
Apr 2, 2019 at 10:40 PM
Good morning,
No, there is no reset for the pump.
Did you check for power to the pump? I attached a wire diagram for you to view. You need to verify power to the pump. There are a couple of fuses listed to check. Make sure you test for power on both sides to be sure power is available.
Apr 2, 2019 at 10:57 PM
MARSHA HICKS
Changed fuel pump but still wont start. the fuse diagram that was sent does not match the one on my vehicle.
Apr 3, 2019 at 2:29 AM (Merged)
