Car will idle but stalls when applying the gas
85,000 MILES
ROGERROB17
I checked the fuel pressure and it's at 38 PSI when idling.
Sep 16, 2019 at 3:53 AM
This sounds more like a mass air flow meter. Your fuel pressure while idling should be between 26-45 PSI so you pressure okay. When you step on the accelerator if the MAF sensor is not reading properly then it will not tell the PCM there is more air coming in and it will stall the engine.
https://www.2carpros.com/articles/mass-air-flow-service
When the engine is idling, is it running rough? Also we need to find out if there are codes to confirm this but just from what you are saying it sounds like a MAF.
Jun 8, 2021 at 7:12 AM
