The truck will not run on the front fuel tank. The switch and relay have been tested and are good and operating properly but the fuel pump on the front gas tank will not prime when the key is turned and the switch is on the front tank. The relay clicks when you have it on the front tank but no power makes it to the fuel pump
SPONSORED LINKS
Tuesday, April 16th, 2013 AT 7:00 PM
