Mechanical fuel pump will not pump! Recently pulled my 390 out of truck listed above. Replaced all seals and timing chain/sprocket as well as oil pump, fuel pump, etc. Initially, it ran fine for twenty minutes or so. The next day, would not start. Was able to suck fuel from the tank through the lines. However, from the pump to the carburetor Nothing. took apart timing cover again to check eccentric. There were signs that the cam dowel was not long enough to engage the eccentric and it was spinning on the bolt. Replaced with a slightly shorter pin and an eccentric that had a tab that went into the dowel hole. Put back together and the pump still will not pump fuel! it will run for a few seconds with fuel in the carburetor so everything on the cam side should be functioning properly. Does it need to primed? I cranked on it off and on for the better part of an evening. I am at a loss! Help!
Jan 28, 2018 at 2:19 AM
