Engine will not stay running after replacing the fuel pump
54,000 MILES • 2.4L • V6 • 2WD • AUTOMATIC
KADI MOTE
Replaced fuel pump because I was driving it and it just stopped one day, I let it set for a day started right up. so, I replaced the fuel pump. It started ran for 15 minutes then stopped and wouldn't start up.
Dec 26, 2021 at 5:30 PM
AL514
  • 5,704 POSTS
Hello, did you replace the fuel filter when you did the fuel pump? I always recommend replacing the fuel filter, and the fuel pump relay when replacing a fuel pump, especially a 1995. A clogged fuel filter is what probably caused the first pump to fail,
I recommend the fuel pump relay too because they get carbon build up inside after so many years and it's good to include it in the replacement.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Dec 27, 2021 at 1:13 AM
