Fuel pump
165,000 MILES • 3.0L • V6 • 2WD • MANUAL
JAMES CASEY
Checked fuel pump using a fuel pressure gauge, no fuel pressure. Replaced fuel pump fuel pressure good. Truck still will not start. the fuel tank was contaminated with water and had floating trash in the tank.
Jul 18, 2017 at 7:42 AM
  • 55,770 POSTS
Please try cranking the engine over and spraying starting fluid into the intake to see if the engine starts. This way we can narrow the problem down.
Cheers, Ken
Jul 19, 2017 at 4:36 AM
JAMES CASEY
Sprayed starter fluid in intake engine started. buried starter fluid up and stop running
Jul 24, 2017 at 2:42 AM
  • 55,770 POSTS
I noticed you had three of the same post did you have trouble uploading or?
We need to see if the injectors are getting pulse here is a guide to help you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Cheers, Ken
Jul 25, 2017 at 4:34 AM
