New fuel pump not kicking on
230,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
OUTLAWMOM
  • 6 POSTS
Installed new fuel pump it is not kicking on. Has a new starter, new ignition.
Jul 17, 2016 at 2:30 AM
HMAC300
  • 48,601 POSTS
check to see if fuel pump relay is sending power to it. if relay is good, try another relay, then try another key it may be the security system is shutting down power for it. if another key does not work have it scanned by a mechanic to see if security system is broken.
Jul 17, 2016 at 3:30 AM
