FUEL PUMP
78,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
GRANNY GRANT
  • 14 POSTS
How much PSI should it pump when the ignition comes on?
Aug 5, 2016 at 2:46 AM
WRENCHTECH
  • 20,760 POSTS
What is the eighth digit of the VIN#?
Aug 5, 2016 at 4:30 AM
GRANNY GRANT
  • 14 POSTS
W.
Aug 5, 2016 at 6:18 AM
WRENCHTECH
  • 20,760 POSTS
That is a high pressure system.The spec is 55-61 PSI and it has to remain in that range. You also want to pay attention to what the pressure does when the key is shut off. Does it hold the pressure or immediately leak down?
Aug 5, 2016 at 6:20 AM
GRANNY GRANT
  • 14 POSTS
I have bought two new pumps and called several auto stores and was told the PSI should be 14 and the truck still will not start.
Aug 5, 2016 at 6:27 AM
GRANNY GRANT
  • 14 POSTS
Both new pumps only pump 14 PSI.
Aug 5, 2016 at 6:29 AM
WRENCHTECH
  • 20,760 POSTS
No, it should not be 14. That is for a TBI engine but you have a Vortec. That is why I asked for the VIN code. You may be buying the wrong pumps.
GRANNY GRANT
  • 14 POSTS
Thank you for your help.
Aug 5, 2016 at 6:36 AM
GRANNY GRANT
  • 14 POSTS
Can you tell me what fuel pump to get?
Aug 5, 2016 at 6:44 AM
WRENCHTECH
  • 20,760 POSTS
The one that is made for your vehicle. You have to be giving them some wrong information. Make sure they are aware you have engine code "W". That matters.
Aug 5, 2016 at 6:46 AM
