Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Cefiro
Fuel System
Fuel Pump
Relay
Location
Where is the fuel pump relay located?
2005 NISSAN CEFIRO
222,222 MILES • 1.3L • 4 CYL
ICEBRAYKABLE
MEMBER
Need to locate the fuel pump relay.
May 24, 2025 at 7:20 AM
ICEBRAYKABLE
MEMBER
My fuel pump not receiving the right amount of voltage 3.8. What the problem why I'm not getting 12v?
May 24, 2025 at 7:26 AM
ICEBRAYKABLE
MEMBER
Where can I locate my fuel pump relay?
May 24, 2025 at 7:27 AM
Experienced Mechanic
Sure, the fuel pump relay is inside into the IPDM. Here is the location. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
May 25, 2025 at 5:27 AM
Add image or video
Ask a new question
Engine stalls while driving
