Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
Fuel Pump
Location
fuel pump location
1991 TOYOTA CAMRY
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LOFTIS
MEMBER
found where pump assembly should be but all I found was the float.
Mar 6, 2021 at 6:00 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
Here is a tutorial for you to view on how to replace an in-tank electric fuel pump:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
You will need to remove the fuel tank to gain access to the fuel pump. I've attached picture steps below on how to remove and replace both the fuel tank and fuel pump on your car. hope this helps and thanks for using 2CarPros.
Images (Click to enlarge)
Mar 6, 2021 at 6:28 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
