New fuel pump is not working
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JSTONE2330
The fuel pump stopped working recently so I replaced it along with the fuel filter (frame) and relay. The new fuel pump is not working. I attached wires from battery to the pump it works. I also checked to see if inertia switch had engaged from these bad potholes but it had not. The button was still seated. Any suggestions?
Jun 5, 2019 at 10:15 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached a picture below of where the fuel pump relay is located under hood and also the wiring diagram.Here is a tutorial showing how to test a relay and wiring:
The relay is ran through the (eca) electronic control assembly.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 5, 2019 at 10:33 PM
