Trying to figure out where the fuel pump is located without having to drop the fuel tank.
Dec 16, 2019 at 7:18 AM
✓Experienced Mechanic
Good evening,
The fuel pump is inside the tank itself. You do need to drop the tank to gain access.
If you are thinking of cutting a hole in the floor, that would be a bad idea. There is a lot on top of the tank, that would be a bad idea. There is way too much on the top to move around to get the module up and out.
