Why is my vehicle stalling after replacing the fuel pump?
200,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
TONI JANSEN
I have replaced the fuel pump two times and fuel filter, also the fuel pump relay and still stalling on me. What could be the problem?
Jul 14, 2022 at 9:19 AM
SQM
  • 6,383 POSTS
So, does the engine just stalls all of a sudden as you are driving?
Are you able to start it back up afterwards?
This could be due to a faulty crank position sensor.
Faulty crank sensor won't be able to send the proper signal to the ECM and that can trigger the engine shutdown. After the shut down the engine may or may not start back up.
Take a look at these helpful guides:
I have attached diagrams below for your reference.
Let me know of any questions.
Jul 14, 2022 at 2:06 PM
TONI JANSEN
When it first started happening the engine would start up again but recently it didn’t want to start a couple of days ago.
Jul 15, 2022 at 8:06 AM
SQM
  • 6,383 POSTS
So, it just cranks and cranks but does not start?
This could be due to a bad crank sensor.
Are you getting any codes?
Jul 15, 2022 at 8:25 AM
TONI JANSEN
No codes at all.
Jul 16, 2022 at 8:40 AM
SQM
  • 6,383 POSTS
Take a look at the guides that I have provided above. It could help you determine the cause.
Jul 16, 2022 at 2:58 PM
