Fuel pump
223,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DENISE WALTER
My four wheel drive does not work anymore. Does that effect the type of fuel pump I purchase? Thanks
Nov 9, 2017 at 1:28 AM
  • 31,937 POSTS
There is only one type of pump that fits, it dos not matter about the manufacturer. is the problem with fuel pressure? has this been diagnosed correctly yet?
Nov 9, 2017 at 8:07 AM
STEVE W.
  • 15,399 POSTS
Fuel pump has nothing to do with four wheel drive, so if you have a bad fuel pump you just replace it.
Now if the question is, will replacing the fuel pump repair the four wheel drive, no. That would be a different problem.
Nov 9, 2017 at 10:19 PM
DENISE WALTER
Well, I was looking for a replacement part on auto parts warehouse the option says 4WD, RWD, and I have a plastic tank. just trying to make sure I get the correct part.
Nov 9, 2017 at 11:13 PM
STEVE W.
  • 15,399 POSTS
If you have a 4X4, it is four wheel drive even if it is not working at the moment. RWD = no transfer case or front drive axle.
Nov 10, 2017 at 12:00 AM
